1 - 2 of 2 Posts
Hi,
Can someone give me some advice on how to remove the crystal on my Wenger Aquagraph Tide watch, model 70832. This watch has a rotating bezel (rotates one direction only) with a mineral crystal. THese are my questions:
How does the bezel pop off (with a case knife?) Will some part goes flying out never to be found again?
Is the crystal glued in or is it a press fit between the bezel and case with a gasket in between?
Any other advice is welcome. By the way, I have a small arbor press to seat the new crystal in place. I may use a sapphire crystal to replace the original mineral.
Mike
Hi,
Mike
First off welcome. I would'nt touch it just go to a professional watch maker you don't want to add more damage to the watch.:001_smile:
1 - 2 of 2 Posts
