Recently I picked these two up. After some TLC they run very will. I did find some information on them, but anything you can add would be great.
The Elgin watch I found some good information.
Elgin Serial Number : C181254
Production Year : 1943
Jewels : 15 jewels
Grade : 554
Model : 7
Run Quantity : 28000
Production Dates : 1940 to 1951
Total Grade Production : 1358000
Movement Configuration : Hunter Case (wristwatch)
Movement Setting : Pendant Wind and Set
Movement Finish : Flat/Matte Nickel Finish
Plate : 3/4 Plate
Barrel : Going Barrel
Adjusted : No
The EMCA watch was difficult to find information on. I'm not sure how accurate the information I have found is.
From what I can tell EMCA was a brand produced by the IOCO (Isidor Ollendorff Co., New York N.Y.)
Most likely around the same date as the Elgin late 30's - 40's
This company and Elgin had some kind of relationship they used some of the same or similar dials and bodies.
The movement is a Eska Watch Co. 17 Jewels.
Jewels : 15 jewels
Grade : 554
Model : 7
Plate : 3/4 Plate
Adjusted : No
