Is there anyone in the forum that has experience and/or knowledge removing the outer rotating bezel. I am assuming it has the hexagon (or muli-gon) spring between the bezel and case as it ratchets when rotating. I have put light-pressure with a case splitter (between bottom of bezel and case) to lift the bezel, but it’s not popping right off.
Model number on back of case (if needed) is 980-0208
Thought is best to reach out before damaging anything.
Thanks in advance,
Will
Thanks in advance,
Will
