1 - 2 of 2 Posts
H, I have a Seiko sportsmatic 5 day/date 6619-8050 from mid 60s. The minute and second hand periodically stop for 5-10minutes and then restart while the second hand keeps moving at normal rate. I checked the cannon pinion under the hour wheel and the tube part is tight on the gear. Minute and hour hands move normally with the crown stem for time setting. I cannot see anything else causing the problem and think it is further inside the movement. Any ideas or help on this?? Thanks
1 - 2 of 2 Posts
