This question can become very complicated. A higher beat movement like the SW200 (28,800BPH) will
always have a smoother sweeping seconds hand (same for the ETA2824) than a movement beating at only 21,600BPH. Seiko has a high beat equivalent as well; the 6R20! The SW200, just like the ETA2824, are available in many different grades; just because it's higher beat does not mean it will be more accurate than a lower beat movement. If both a low and a high beat movement are equally certified for the same accuracy, there is a theory, however, that the higher beat movement will maintain that accuracy better regardless of hard use (quick hand movements, vibration, sudden wrist rotations, repetative shocks as when playing golf, etc.). Need more info? :confused1: See if this doesn't put you to sleep!
Frequency Response of a Watch Escapement
