Okay, before I begin, Zin please do not kill me
Tonight I decided to remove a link from my PO since I felt I may want it to be a little snug on me. Now, this is not my first time doing this. My invicta's have had their links removed by me in the past without any problem. However, I have known--from fellow members on this board--that remove the pins in an Omega can be rather difficult. Well, I attempted to do this tonight and I am somewhat worried as to what I have seen. I will be providing pictures to illustrate what I have done.
First picture:
Here you will see my Omega with a link already remove and a pin sticking out. My link remover pushes the pin up to this point but it is very hard to pull out. So, I took my leatherman and pulled the pin out. Now, before anyone screams at me, I had no choice and this seemed like the only way possible. As many of you know there are arrows on the links, which I assume, are showing you the direction you need to insert them. So, is it safe and correct to say that if you want to remove them you go the opposite way? That is what I did.
Second picture:
This is the one that scared me the most. As I was pushing this pin out, in the direction of the green arrow, a little piece of the pin fell out which about gave me a heart attack. The pick is labled with a "1" and where it came from is labled with a "2". IS THIS NORMAL?!!?!
EDIT: I have come to realize what that little pin that fell out is. It is actually the mechanism that I have to push the pins out. It actually broke. So, I can report that none of the Omega pins broke.
Third and last picture::
You will see here my technologically advanced pin and link remover. If you have any recommendation on a better one please refer me to a link.
First picture:
Second picture:
