1 - 2 of 2 Posts
I just bought this watch. the crown does not "screw down tight" it only closes to the wind position. is this normal? how is it waterproof if it is indeed normal? or do i have a defective watch that i need to return
Thanks for the help /advice
plmbchbkr
Can you provide a model number? It should be on the back of the watch. It doesn't sound like its a screw down crown. It either is or isn't. The threads will be visible on the case when you pull the crown out. If its not a screw down there will be gaskets within the crown to maintain water resistance in the closed position but I still prefer a screw down crown.
1 - 2 of 2 Posts
