1 - 3 of 3 Posts
I used to have a 40mm ss/plat Yachtmaster but eventually traded it because I didn't like the lugs being smaller than the endlinks. Now on the 2012 version I see that the endlinks and lugs are flush (or virtually so) like on the latest Sub-C's, Explorers, etc.
Question to the experts... Are the 2012 lugs now longer than pre-2012? By comparing the two attached pics, it seems to me that the 2012 endlinks are shorter, but did Rolex make the 2012 lugs longer as well?
Thanks
Well since no one has actually held one, anything said here will be only a guess.
However, I'm going to guess the case stayed the same based on everything else I can see and they just fixed the end link on the new bracelet. But again, that's just a guess and the only way you're going to be 100% sure of which it is is wait for them to get to the stores & personally compare the two side by side.
On a side note, the more I see that blue dialed Yachty the more I'm losing resisting the temptation to get one..... :001_unsure: :001_unsure: :cool1:
1 - 3 of 3 Posts
