Discussion Starter #1
What is the difference between the original Pro-Diver and the newer model S2. They are the same price.
After seeing the thread on "The Legend" I'm buying one to wear when I don't mind being a little rough with the watch I'm wearing.
Which one would you guys buy?
I believe the S2 may use the newer and larger case design of 43mm and if I'm not mistaken, the original 8926 uses a 40 mm case. In terms of which is better, both are at the same level in terms of quality I'd imagine as they occupy the same price range, I'd just pick whichever size you prefer.
Discussion Starter #3
Thanks! I ordered the S2.
