1 - 2 of 2 Posts
provides power to keep the clock going.
In mechanical clocks, this is either a weight suspended from a cord wrapped around a pulley, or a spiral spring called a mainspring.
In electric clocks, it is either a battery or the AC power line.
Since clocks must run continuously, there is often a small secondary power source to keep the clock going temporarily during interruptions in the main power. In old mechanical clocks, a maintaining power spring kept the clock turning while the mainspring was being wound. In quartz clocks that use AC power, a small backup battery is often included to keep the clock running if it is unplugged temporarily from the wall.
1 - 2 of 2 Posts
