The winged hourglass symbol on the inside of the case was used into the early 50's I think. If the serial number on the movement is 2,18x.xxx (can't quite see it) it's from 1908, and if it's 3,18x,xxx then it's from 1914. Can you tell me what that number is? I'll be better able to ID the movement that way too.
