I know I shouldn't do but am considering buying the attached without having had the back removed (owner doesn't know how to get the back off). Does anyone know if this looks real or can id the dial? Omega Reverse.JPG Omega Face.JPG
That might explain it. Is it a front or a back opening case?
Back. There's a wrench with adjustable pins that fit in 3 of the 6 slots that will allow you to unscrew the case back. Or, wad up some packing tape so the sticky side is out, press down and twist. (don't use this method on any case back with a painted medallion)
