Hi all. The first time I posted here was to inquire how to manual wind a 9937 with a SW200. Well, I returned the watch. After resizing it, the watch fell because the screw on the bracelet fell off, I couldn't find it. I also noticed before that there was a minor chip on the case, which I overlooked, but after the bracelet, time to go.
What I did was get a refund because I found out, the retailer no longer has the 9937 and will not be getting any more.
I was able to snag an older 9937 with the ETA 2824. I hope this will last me a few years until I get a different submariner homage.
Couple of complaints I had about the SW200 movement. The rotor was terrible. I mean really had to shake the watch to get it to move. I had seen videos of 2824 movements and the rotor moved with a nudge. So either Invicta messed up with their decorated rotor or SW200 rotors are not up to par with ETA's. The other part was listening to the quick beating of the movement. SW200 once in a while sounded out of time. This ETA is steady, and constant. I also noticed time keeping. The SW200 kept GOOD time. But ONLY when it was at perfect level. If I wear it, sometimes it's 15 seconds off, sometimes 4 F***ing minutes off...
Then I read SW200 movements comes in different grades and Invicta may use the lowest grade. Maybe lowest grade means defective? I don't know, but I was underwhelmed needless to say. So I went searching for a ETA 2824 and found it. Will begin saving up for a diver watch with ETA at reasonable price but more original design
