1 - 2 of 2 Posts
hi guys, i´v being trying to replace the batt of this watch , and i´v the problem that i´v to remove the band previously.
I cant have access to the screws, i dont know how to do this.:mellow::mellow::mellow::mellow:
someone had tried it ?
My first thought is... why not just trash it and replace that Invicta with a real watch? But then common sense took hold of me and i thought "I shouldn't really say that" so.... I did what most people would do and did a google search for "How to remove the poly strap from an Invicta Venom". There are pages and pages of information on Invicta watch problems. This is what i found:
'To remove the poly strap from your Venom, you have to release the spring loaded pins from the underside of the band. There are two on both ends. Re-use the pins with the band but be careful not to have a pin go into the wrong hole because they can't be removed without breaking them!'
1 - 2 of 2 Posts
