1 - 2 of 2 Posts
I have a invicta 11807 with a foggy crystal.
I have cleaned a few in the past but this movement is new to me and I cant see how to remove it. I already have the back and crown stem removed. I lift up on the movement and it can wiggle a little but wont lift up. There are a few small screws that go around the movement but im afraid of damaging it. Can anyone confirm how this comes out?
someone said it may be a front loaded watch, but would the back still come off if that was the case?
Maybe the bezel needs removed... just not sure
225409
225410
225411
Thanks in Advance
before you do that, try one of those little packets that come in perscription bottles.take batt out and just push it in.In a day or two it should clear up.I first tried this on a 224Accutron that looked like a fish tank.I didn't know the first thing about removing the mvmt back then;so I used what I had.I imagine you could also put a glass over it to expediate the effect.costs zip,and actually works.
1 - 2 of 2 Posts
