A few questions on gold Bulova cases:
What is the difference between "14K Gold Filled Case" and others - such as I know the few 18K cases that were produced by Accutron are often referred to as "solid gold." Are the 14K filled just gold plated? Did Bulova make a 14K case that was more solid or heftier than "Gold Filled"?
My 218 is 14K Gold Filled, and just recently I noticed one small place where it appears the gold has begun to chip, at the bottom of one lug. You have to be in fine-tooth mode to find it, but I know it is there. Is this something to worry about or will it get worse? Note this watch (an M9) was an everyday wearer for probably at least 25 years out of it's nearly 44 so far, and I still wear it probably at least 3x a week.
Thanks.
Thanks.
