FS: 24mm Diver Clasp Heavy Wire Mesh Watch Band - 5 styles
24mm Polish "SHARK" Mesh Extra Short Divers Watch Band Bracelet
[DC242003P005XS], US$69.99
Lug width/Buckle (mm) : 24mm / 20mm
Length (mm) : 132mm , Extra Short Length
Min.length after adjusted : 125mm
Buckle : Stainless Steel Double Flip-Lock Diver Clasp
Thickness (mm) : Mesh : 4.0mm
Net Weight (gram) : 53gram
Finish/Spring bar dia. : Polish / 1.78mm (24mm Spring Bar included)
Lug end style : Straight End
Adjustment type : 3 Mirco hole type adjustment
Material : Stainless Steel, 1.2 Wire Mesh
New Flexi 24mm Polish Flatten "SHARK" Mesh Divers Watch Band Bracelet
[DS242001P004], Polished, US$76.99
[DS242001B004], Brushed , US$76.99
Lug width/Buckle (mm) : 24/20 (Tapered)
Length (mm) : 190mm (Flexiable length adjust design)
Min.length after adjusted : 130mm
Thickness (mm) : Mesh : 4.2mm
Net Weight (gram) : 73gram
Finish/Spring bar dia. : Flatten Design /1.78mm (not included)
Adjustment type : 4 Mirco hole type adjustment
Design to fit 24mm Lug All watches with 24mm lug width
Massive 24mm Divers Clasp Mesh Watch Band Bracelet, Solid Link Adjust
[DC242403B003], US$62.99 , 138g , Push button
Length (mm) : 200mm , Min.length after adjusted : 145mm
Massive 24mm Divers Clasp Mesh Watch Band Bracelet, New Solid Link
[REG-DC24-003], US$62.99 , 107g
Length (mm) : 165mm , Min.length after adjusted : 125mm
Lug width/Buckle (mm) : 24/24
Thickness (mm) : Link : 6.0mm , Mesh : 4.20mm
Finish/Spring bar dia. : Satin /1.78mm
Adjustment type : Pin push type adjustment
Material : Stainless Steel, Solid Link + 1.2 Wire Mesh
24mm Interlocking Stainless Steel Mesh Diver Watch Band Bracelet
[DC242403B002], US$48.99
Length (mm) : Range from 160mm to 135mm, please select the length from below table
Min.length after adjusted : Range from 155mm to 130mm, please select the length from following
AA : max. 160mm , min 155mm
AB : max. 145mm , min 140mm
BB : max. 135mm , min 130mm
Buckle : Solid Stainless Steel Double Flip-Lock Diver Clasp with Push Button
Thickness (mm) : Mesh : 3.80mm
Net Weight (gram) : the longest in 78gram, shortest in 71gram
Bracelet Finish/Spring bar dia. : Satin/1.78mm (24mm Spring Bar included)
Wire Mesh Band 24/24 Heavy Stainless Steel Divers Double Clasp-Solid Link
[DC242403B001], US$69.99
Lug width/Buckle (mm) 24/24
Length (mm) 178mm
Min.length after adjusted 130mm
Buckle Stainless Steel Double Flip-Lock Diver Clasp
Thickness (mm) Mesh : 4.40mm / Steel Solid Link : 4.90mm
Net Weight (gram) 106gram
Finish/Spring bar dia. Satin/1.80mm
Lug end style Straight End
Adjustment type Pin push type adjustment
Material Stainless Steel, Solid+1.2 Wire Mesh
FREE Ship Worldwide
US & UK & Asia & Australia - Ship by register Airmail , others by Airmail
Pls Contact : [email protected] / Paypal : [email protected]
We offer special discount on group buying. Please do not hesitate to contact us with any questions you may have.
Thank You
