Flexi 20mm ”SHARK” Mesh Divers Watch Band Bracelet
(Also avaliable in Lug 22mm)
[REG-DC2020-004SD] US$69.99
Lug width/Buckle (mm) : 20/20
Length (mm) : 195mm (Flexible length adjust design)
Min.length after adjusted : 135mm
Buckle : 316L Stainless Steel Double Flip-Lock Diver Clasp
Thickness (mm) : Mesh : 4.60mm
Net Weight (gram) : 69gram
Finish/Spring bar dia. : Satin/1.78mm (20mm Spring Bar included)
Lug end style : Straight End
Adjustment type : 4 Mirco hole type adjustment
Material : Stainless Steel, 1.2 Wire Mesh
Design to fit 20mm Lug
20mm Interlocking Stainless Steel Mesh Divers Watch Band Bracelet
[DC202003B002], US$41.99 , Length (mm) : 165mm, Min.length after adjusted : 158mm , 70g
[DC202003B002XS], Extra Short , US$41.99 , Length (mm) : 150mm, Min.length after adjusted : 143mm , 65g
Buckle : Solid Stainless Steel Double Flip-Lock Diver Clasp with Push Button
Thickness (mm) : Mesh : 3.80mm
Bracelet Finish/Spring bar dia. : Satin/1.78mm (20mm Spring Bar included)
Adjustment type : 3 Mirco hole type adjustment
Wire Mesh Band 20/20 Heavy Stainless Steel Divers Double Clasp-Solid Link
[DC202001B001], US$55.99
Length (mm) : 180mm
Min.length after adjusted : 130mm
Buckle : Stainless Steel Double Flip-Lock Diver Clasp
Thickness (mm) Mesh : 4.40mm / Steel Solid Link : 4.90mm
Net Weight (gram) : 88gram
Finish/Spring bar dia. : Satin/1.80mm
Adjustment type : Pin push type adjustment
Material : Stainless Steel, Solid+Mesh Wire
316L Wire Mesh Band 20mm Stainless Steel Divers Double Clasp, Solid 316L Link
[DB202003B001], US$62.99
Length (mm) : 180mm
Thickness (mm) : Link : 5.0mm , Mesh : 4.0mm
Net Weight (gram) : 99[/B]gram
Material : 316L Solid Stainless Steel + 316L Mesh Wire
FREE Ship Worldwide
US & UK & Asia & Australia - Ship by register Airmail , others by Airmail
Pls Contact : [email protected] / Paypal : [email protected]
We offer special discount on group buying. Please do not hesitate to contact us with any questions you may have.
Thank You
