1 - 9 of 9 Posts
Bulova has had an "Ambassador" line of watches since back in the 1930s. In the 1960s the line consisted of a variety of styles using the Bulova micro-rotor automatic movements based on the Buren 1280/1/2 and 1320/1 movements. This Bulova movement came in a variety of calibers in 17 jewel & 30 jewel variations:
12EBA - time only (hour, minute)
12EBAC - center seconds
12EBAD - time only (hour, minute) and date
12EBACD - center seconds and date
12ECAD - time only (hour, minute) and date
12ECACD - center seconds and date
One variation of this movement (12EBA) is shown below:
Interesting features of this movement family include:
- Integrated micro-rotor with unique transfer wheel sandwiched between two jewels.
- Eccentric screws for both beat & rate adjustment (see balance bridge above)
- Offset center wheel with integrated cannon pinion
- Indirectly driven center seconds
- Unique date changing mechanism which, although not a quick-set, allowed the date to be rapidly advanced by moving the hands between 23H & 24H.
- Very thin at 2.85mm (12EBA) - 3.6mm
In general, after 1965, these Ambassador model watches used one-piece cases (movement comes out the front) with improved water-resistant characteristics. All of the watches shown here have one-piece cases.
Pictured below are a variety of Ambassador models from this period.
From 1965:
From 1966:
From 1967:
From 1968:
This is one of my favorites. It's really a classy looking watch. This watch uses a 14K gold bezel with a stainless case & original gold band.
From 1969:
From around 1970 I think:
The "Ambassador" series is a very handsome collection
Jim H the one you singled out as one of your favorites, IS my favorite also.
I would love to own any one of those Ambassadors. Great photos!! :001_wub:
i bought a couple few days, the Ambassador of 1967 automatic 30 jewels, but i have a doubt, how can i open the watch, because i cant see in te back case marks to turn the lid,no nut to accommodate screw-on box opener
It is the same as the link that I add to this comment
somebody help me?
tks
It might be a snap back case but the 'Ambassadors' were generally a solid one piece case in the 50's & 60's so the movement likely comes out the front. You'll need to remove the crystal (use a proper tool) and the crown needs to be separated from the stem (hint its a split stem as shown below) before you can remove the movement.
225432
Does anyone have an idea of how common they were? I’ve got the no date, no center seconds version, and I rarely see them listed
I don’t believe they were “common” but I do see them from time to time. I’ve had a 30 jewel date version for several years. I shared it on My Bulova and was told it probably wasn’t a Bulova factory piece, despite seeing others exactly like it listed. Some criticized the micro rotor as being too small and lacking enough inertia to keep the watch wound from day-to-day if there wasn’t much arm activity. I’ve never experienced that issue.
1 - 9 of 9 Posts
