I brushed this one,
it's hard to tell, but the best pic I have.
as easy as it is to scuff those center links you'd think it would be easy to brush them.
I removed the bracelet from the watch and used a 200 grit foam sponge like 3m product to rough it up and remove all the(most) deep scratches first.
I had to get between the links so I bent the bracelet at each link and got in between there, then sanded untill the brushing looked straight and even.
then I used a scotchbrite pad to smooth it just a bit.
little bit of work but it turned out looking just like my other 'all brushed" bracelets..
take your time and make sure you go one direction like Mr Ecm3 and others said and it will look great.
diver88
