1 - 3 of 3 Posts
Hello all,
A few months ago I purchased an Invicta 8926OB from Amazon to use as a beater and project watch . So far, I've changed the band and sanded the center links. Next, I would like to change the hands, and bezel. Basically because I lost the original bezel pearl, and I'd like to replace the original (slightly green) mercedes hands with white ones.
Here's the problem, I don't know where to find the correct size bezel and hands replacement parts.
Regarding the hands, the watch has the newer NH35A movement so I want to make sure that I'm getting parts that fit correctly.
Regarding the bezel, I'm interested in either ceramic or traditional styles, as long as they fit correctly.
I've done research on the internet searching for the hands. The problem is, that the hands I found fit the NH25A movement, not the NH35A (Seiko).
Has anyone done these mods and can point me in the right directions of where to look for parts?
I've attached a picture of the watch as it looks currently for reference.
I really appreciate everyone's time an consideration on this.
Jae.
I got a set of hands from dagazwatch for the nh35 movement since bascically the movement is a seiko movement and also got a bezel from Invicta for. 11.00 bit there is a catch the higher msrp the higher the cost for the watch part
1 - 3 of 3 Posts
