1 - 2 of 2 Posts
Hey all
I just got an Ocean Reef 6762 and need to re-size the bracelet but there are no arrows pointing the way and I'm a bit stuck.
The pins dont seem to be the standard ones and I was hoping someone was familiar with these and could help out
Thanks
I believe this model uses a pin and collar system. The pins are held in the bracelet by a collar/sleeve within the center link. They are a little tougher to get out but the principle is the same. A watch tool kit will comes with a little hammer and some pins you can hammer through to push the pin out. I can be a little tougher. Use a tool that is as thin or thinner than the pin so it will fit through the collar. Just be careful when the bracelet comes apart because the center collar within the center link can slip out and become lost.
1 - 2 of 2 Posts
