2 new LÜM-TEC M series models for 2018! Sandwich dials with massive amounts of lume and ETA automatics!
M80 and M81. Pre-Order opens today (1-5-18) starting at $743.75
Specs:
*Assembled by hand in Ohio
*44mm case width excluding crown
*24mm lug width
*Surgical grade 316L stainless steel
*Threaded see through sapphire caseback
*Bead blasted finish (M80)
*Brushed finish (M81)
*Titanium Carbide PVD hard coating (gunmetal tone) (M80)
*Double curved sapphire crystal with military grade anti-*reflective coating
*Swiss ETA 2824-2 automatic movement
*Anti-Shock movement mounting system
*200 meters/656 ft. water resistance
*Black bead blasted PVD dial base
*MDV Technology® dial and hands with grade X1 LOR (M80) and C3 (M81) Super-Luminova®
*Screw lock crown with double diamond sealing system
*High tech Viton® gaskets
*Brown croco calf leather strap with PVD buckle (M80)
*Black croco calf leather strap with brushed ss finish buckle (M81)
*Black Anti-Static molded rubber strap with PVD buckle (M80)
*Black Anti-Static molded rubber strap with brushed ss finish buckle (M81)
*Lifetime free movement timing regulation
*Lifetime free pressure testing and seal lubrication/cleaning
*2 year international limited warranty (fully transferable)
*Limited and numbered to only 100 pieces worldwide
Specs:
*24mm lug width
